Globally enable or disable EAP on the switch. By default, EAP is disabled.
- Select 802.1X - EAPOL.
- Select the Global tab.
- From the AccessControl options, select enable.
- Optional: Select the appropriate NonEapRadiusPwdAttrFmt check boxes to configure the format of the RADIUS password when authenticating non-EAP MAC addresses using RADIUS.
- Optional: Enter the key string in NonNonEapRadiusPwdAttkeystring.
- Optional: Select ClearNonEap to clear the NEAP session that is learned on the switch.
- Optional: Type an I-SID offset number in AutoIsidOffset.
- Optional: Select AutoIsidOffsetEnable to enable Auto I-SID offset on the switch.
- Select Apply.
Global Field Descriptions
Use the data in the following table to use the Global tab.
Name |
Description |
EapolVersion |
Displays the EAP version on the switch. |
AccessControl |
Enables system authentication control. EAP is disabled by default. |
NonEapRadiusPwdAttrFmt |
Specifies the password attribute format for non EAP RADIUS authentication.
NonEapRadiusPwdAttrKeyString |
Specifies the attribute key string for non EAP RADIUS password. |
ClearNonEap |
Clears the NEAP session that is learned on the switch. |
AutoIsidOffset | Specifies the Auto I-SID Offset value. |
AutoIsidOffsetEnable | Enables or disables the Auto I-SID Offset feature. |
